I have killed a lot of brain cells messing with VCAs even back before they didn't suck (THAT VCAs at least).
One topology that promises low noise and low distortion for unity gain is to use the VCA subtractively. For unity gain the VCA is completely out of the circuit so zero noise and zero distortion from a simple op amp. To command attenuation you just subtract more of the input signal. -20dB of path gain results from subtracting 0.9x of the original signal. Of course there is no free lunch so this is higher noise for deep attenuation than conventional topology. This is actually quite nice for a limiter comfortably running in the 0db to -12dB range. A little higher noise/distortion when commanding -12dB attenuation seems acceptable.
