If you cannot get the simulation running in Tina try LTspice. It works there. Though instead of actual logic gates, I use two voltage sources with square wave outputs of opposite polarity. Maybe that will also fix your problem?
Jan
Jan
the more i get irritated by phantom power limitations
As I've mentioned before, I'm a great one for 'simple' inside the mic, and to move everything else (eq etc) further down the signal path.I've been tinkering with diverse variations of your OPIC circuits, and the more i play with them the more i get irritated by phantom power limitations. If all those tube mics have clunky PSUs that follow, why wouldn't we have dedicated PSUs for opamp based mics? This is definitely my next step. No more hustle with voltage multipliers, no limitation of how many opamps in a mic we get to use for various purposes, and the benefit of basically unlimited headroom is priceless.
I just want a mic where capsule's SPL limitation is the only limiting factor and i believe this is the way to go. Sorry for this rant, just had to share some frustration after several hours of LTspice desperation.
My post was certainly not a critique towards your original design which is marvelous. It led me to further experimentation for which i just need more juice.Of course if you want to include more op-amps internally, for other functions, then those figures would no longer compute.
No, I didn't read you post as being critical .... I was just intrigued to know why you needed more power.....My post was certainly not a critique towards your original design which is marvelous. It led me to further experimentation for which i just need more juice.
I'm testing R5 with a value of 10R, wich should be supplying the flat 47 capsules with around 72V, after deducting the opamo half rail bias voltage. Ari has mentioned the capsules should be able to handle 75V. Well, capsules appear to handle 72V well, no issues so far in my testings. I wonder what value could be choosed to get exactly around 70V, somewhere around 180-200 ohm?I have one of Ari's Flat 47's fitted into a multi-pattern OPIC. That is fitted with the original VM, and I have R5 fitted as 1k.
There are 3 op-amps in that circuit, and the circuitry draws c.7mA in total from the phantom power supply.
That provides a DC supply to the op-amps of c.16v.
R5 is fitted as 1k, providing an output polarisation voltage of 70 volts - measured at the cathode of D7 - so that the actual voltage applied across the capsule is 70v, minus the op-amp 'half rail' bias voltage - which is 8 volts.
So the capsule actually has 63v across it.
I think the 'R5' Khron is describing refers to the output series resistor in the newer 'adjustable' version, which is 1M and, as he suggests, is not a critical value.
One final point. I have specified a CD40106 as the VM project hex inverter.
It is of course possible to use alternative types of 40106 - like the HEF40106 - but the thresholds are a bit different, so the output voltages may vary a little from the values listed in this circuit. For example, you would probably need to fit R5 as 2k2 to get a 72v output from a VM fitted with a an HEF40106 intead of a CD40106.
For the newer 'variable' type, this is not a concern of course....
[...] I know Ari has mentioned this capsule is better served with the more open 47 style grill, but I actually like the transparency of the HL77 bodies' 87 style basket I'm using on these. The only thing I've noticed, is that the Flat 47 has some hefty low end reach, and with no filtering going on in the circuit, its usually to much "boomy" for close micing in directional pattern. Almost always I'm using them with low cut on the preamp, and sounding great like that. Of course for kick, padded, that low end reach is welcomed, so I'm not saying I dislike that, just some observations on this combo. Anybody notice this too?
Yes, I have some adhesive tar from way back in my "audiophile" DIY days. .You could use adhesive tar inside the body : it's quit heavy, not so thick and damps vibrations very well. I think you can find it in most hardware shops.
I use it to wrap bass reflex vents in my speakers (for example) or to damps electronics chassis (enclosure)
