You put 6V DC on the input to the audio circuit? I don't follow what you were attempting to do.
Do you have a schematic for this bypass board you have mentioned? Relay coils are isolated, so it seems like there should be no reason for a bypass to introduce a power connection anywhere else (although one end of the coil could certainly be tied in to a common circuit node on the board, and that could be a potential problem source).
If you are referring to that 330nF capacitor in front of the regulator, then yes, you need more capacitance. I don't know what kind of current you need, probably 100uF would be a good starting point for low current, but you should calculate based on current draw.
Oh, I see as I was typing this RoadRunner recommended 1000uF. That works, should be around the same size and cost and will handle more current if you need it.
That is another thing which does not make sense in the original design. The one big advantage which transformers have is ultra high common mode impedance, which means that transformers can reject common mode noise even when there is a fairly large imbalance in source impedance between each leg, such as from an unbalanced output. Having a separate unbalanced input which bypasses the input transformer is taking the single thing which can make the biggest improvement in noise rejection on an unbalanced input and throwing it away. It is exactly the opposite of what would make sense.
If you want to connect an unbalanced output to this EQ just make an adapter cable and use the input transformer for what it does best.
