I’m not sure I understand what you mean here because just prior to the above quote you saidAdding a little jumper from ground on the board to the chassis changes nothing
When you say “Adding a little jumper from ground on the board” which board do you mean? The bypass board?I just removed the yellow wire from the rectifier board to AC ground and drastically reduced noise to almost nothing
