easy quick noob GSSL bypass question
angelo2979
Hi there,
I'm slowly finishing my second GSSL project, I just don't remember how to make the bypass section. I mean simplest, easy bypass (not "True") , or maybe "compression bypass".
I guess it's a very easy question so I hope you don't mind if I post here for a quick solution - and believe me, I even feel guilty for asking!
So, questions..
while in my first GSSL I remember I followed someone's suggestion of making a breadboard to host a relay in  a +- 12v path with regulators, caps, etc I also know it should be as easy as wiring a 12v relay + led +  switch directly to the Control board, right? Why the need for a dedicated breadboard and the other stuff?
...Second option I can figure out here is to use an old supersidechain board. I don't need the filter section, so I could just stuff the relay section, and also use it to wire meter, leds, etc. But here the problem is practical... I only have 2 x 12v relays in my pockets, where the Sidechain BOM tells me 24v relays are needed. Maybe I can fix that without having to place an order just for a couple of relays?
hope it makes sense,
thank you for your attention!
