Hello! Just built this mic and seems like the output is low - it measures about 8db less than the matachung c12 I built a few months back.
Here's what I've done so far:
- Confirmed all voltages stated on the schematic
- Swapped cables
- Used a different power supply
- Have a beesneez 13:1 torroidal installed, swapped for a cinemag 2048
- Confirmed the lower output happens in all patterns
- Swapped tubes
I see about 30V on the backplates, 14V on one of the capsules in cardiod if that helps. Polarity seems to be doing what it's supposed to.
Sounds great, no weird noise - just wicked quiet.
One difference between the mics is the capsule, the 251 has an OPR, the c12 has a beesneez. I'm under the assumption that they will both put out about as much signal - didn't want to dive into swapping capsules until I can verify there's nothing wrong with the circuit. Anything I should measure?
Oh - I also checked that there was no continuity between diaphragms and backplate.
Have pretty much A/B'd everything except the capsule. Anyone have any ideas?
- Swapped cables
- Swapped tubes
