Steve Jones
I have been an advocate of replacing electrolytic capacitors in old gear for a long time. Because so much of the gear that comes into my service shop is in the 15-30 year old range, I believe that there is no harm and some real benefit in replacing these caps in general. (Tantalums of course are replaced without question). Many would disagree with me, for whatever reasons, but no-one has given me any really solid reason to leave ancient electros in old gear, usually it is a kind of "well, it might change the sound" kind of answer.
We know that these caps dry out and go down in value, and that they need power to keep the electrolyte intact and to stop it thinning. I would wager that just about every old piece of gear has had at least one or two times in it's life where due to failure or falling out of vogue it has been left under a bed or in a cupboard for years on end with no power. This is fatal to electrolytics. Then they get turned on again with full power, so they can't self-heal properly, and suffer even further. These caps weren't designed to have service lives in decades anyway. All of the old synths that I have re-capped have had positive sonic or envelope timing results from being re-capped, and power filter caps that have borne the brunt of surges and spikes for decades are definately candidates for failure.
So, after all the prattle, my question is this: If I replace the electrolytic capacitors in say for instance a Urei 1176 with good quality new caps, then calibrate the unit to factory spec, why would this have anything other than the effect of rendering the unit as close to how it was intended to sound new? Is there some "voodoo" or "X factor" in dried out old caps that will kill the sound of the unit? Some would say so, but my ears don't tell me that at all. So if anyone has any science that says otherwise, I would love to know!
