industrialarts
- Joined
- Oct 1, 2020
- Messages
- 130
Hi
I just had an Arp Omni on my bench for repair that has an impressive amount of tantalum caps - 50-75, maybe - and the majority of them had failed. This is something I encounter often in gear of this vintage.; tantalum caps from this era seem to fail often and usually present as a near or dead short. This unit was DOA but after quickly finding the shorted supply bypass caps, it was pretty much up and running.
A large portion of tantalums were used in the keying circuit, so replacing with electrolytics was fine. I did read a lot of posts regarding this and didn't come up with a solid answer - what are the issues with replacing all the supply bypass caps with electrolytics as well? I understand that one of the major benefits of tantalum is large amounts of capacitance in a small package but if space is not an issue then what other factors could be problematic? In fact, the replacements for the keying circuit were actually physically smaller than the original tantalum caps. Plus, my research suggested that you should overate the voltage of the tantalum caps by 2 - 3 times the working voltage, whereas electrolytics are usually in the area of 1.5 or so. Plus, tantalum caps cost about 10 times as much as an equivalent electrolytic.
One thing I was thinking about was in-rush current if there is a considerable amount of caps. Is there much of difference in that respect? Is there anything that makes a tantalum that much better for supply bypass?
BTW, in case anyone is curious, I have been using the Wurth electrolytics for anything in the 1uf-47uf, 35-50vdc range. You can get them from Mouser, they have great specs and look cool as well
