Standard or Pro edition? I am EasyEDA user, too. I am still using the standard edition.I've been using EasyADA also - I got some PCBs last month that were really nice quality.
I've only been using the standard tooStandard or Pro edition? I am EasyEDA user, too. I am still using the standard edition.
Back in the day there was a cost associated with vias, since it meant yet another drilled hole, these days AFAIK there is no marginal cost associated with it.How important is it to not have vias?
Ideally it is easier to troubleshoot when you don't have lots of vias... even worse for troubleshooting are multi-layer boards where traces can hide in middle earth.I've read they're bad, but some seem unavoidable when routing
Standard edition for meStandard or Pro edition? I am EasyEDA user, too. I am still using the standard edition.
At one point ExpressPCB had a maximum hole count which if exceeded had an extra cost. They changed that policy but the layout software still counts them.How important is it to not have vias?
[I expect Midnight Arrakis will chime in here with a long reply] -- I'm hurt!!! I guess all of my studies of "Journalism" has made me "overly verbose" in my technical explanations of things here in this forum. Perhaps I should concentrate more on the "Readers Digest" version of things, huh???I totally understand!
I guess that snapshot was from Kicad? shrug....looks like it to me.
I seldom do PCB layouts anymore, but Kicad is what I use.
In Kicad,you can set "Design Rules" which establish spacings for things like traces and how close to the edge, etc. The PCB manufacturer has corresponding rules. See what the PC board fab says for their standards and then add "a mil or two" on the layout.
I ASSume you already corresponded the pin differences between DIP9 and TO5-8. That always seems to confused me! lol
I expect Midnight Arrakis will chime in here with a long reply and I'll bow out <g>.
Bri
[make a combined footprint for the opamp that has both footprints] -- While this is an excellent suggestion, there is "another way to skin the cat" and it is the methodology that I typically use when faced with this dilemma. However.....since I am unfamiliar with the features and functions possible with the typical -- FREE -- PCB-design CAD programs that are commonly used by users of this forum, I do not know if my suggested methodology is doable/feasible/workable with these programs. Anyway.....here goes.....A better way to do it might be to make a combined footprint for the opamp that has both footprints, connected in the footprint. I just tried this quickly and the attached image is what it looks like.
If you want to try this, click on the DIP part in your schematic, then open the footprint manager from the tools menu.
Search for your part's original footprint on the right side, then click on it. A green edit button will appear.
When you click edit, it will open the footprint in a new window, which you can now edit. You can move and create pads and create tracks. I added 8 pads in the circle and create tracks between them and the DIP pads. I turned off the solder mask on the right two pads by left clicking and going into the pad properties and making the 'solder mask expansion' = 0
I'm not sure if this should be zero or not - probably have to research that a bit.
After you finish making the footprint, save it into your workspace.
Then you can assign the footprint to parts in your schematic through the footprint manager.
[How important is it to not have vias?] -- As Mr. John Roberts has mentioned.....it doesn't matter anymore how many vias your layout has. It -- USED -- to matter "back in the old days".....but, not anymore!!!How important is it to not have vias?
I was just making a joke....which is why I added the <g> to indicate I was grinning. Didn't intend to be critical. Your comments are always instructive![I expect Midnight Arrakis will chime in here with a long reply] -- I'm hurt!!! I guess all of my studies of "Journalism" has made me "overly verbose" in my technical explanations of things here in this forum. Perhaps I should concentrate more on the "Readers Digest" version of things, huh???
[I was just making a joke] -- I knew that!!! And.....my answer was a "joke" as well. I know you well enough from many other posts that you were just kidding!!! However, I figured that my - humor - was a bit too subtle to perhaps easily recognize it as such. Online humor can be a rather difficult emotion to convey, no???I was just making a joke....which is why I added the <g> to indicate I was grinning. Didn't intend to be critical. Your comments are always instructive!
Bri
In that case, combine that into a new library and save it...so I can use it in EasyEDA laterThanks! I’m using EasyEDA
I’m probably way less experienced with this kind of thing than the average user here
Hi,I'm entirely self-taught so please forgive the super basic question.
If I wanted to be able to accommodate both a TO5-8 footprint and DIP-8 footprint, is this an okay strategy?
For all I know this is a super common thing to do--I've seen it done with through-hole DIP-8 and smaller SMT packages, but I can't recall ever having seen it done with DIP-8 and TO5-8. The only question is whether some of the pads might end up borderline too-close. Otherwise it seems it could work okay.
Any reason I shouldn't do this?
Thanks so much
