this thing is done, wound a new OPT, Princeton Reverb type only on a 75 EI instead of 625 EI, 1/8" thicker tongue,
fired it up, runs but rice krispie sounds, ripped it apart again, installed 100K 2 w in place of 100K 1/2 watt, no more cereal, replaced phase inverter with 12AT7 as 12AX7 showed hi freq osc at certain freqs,
problem went away, replaced 75K inverter plate resistor with 82 K, rebiased pwr tubes and it sounds great,
original output was a real mess of wires, hope the pwr trans will be ok,
