peter purpose
You've either done something wrong, or you've done something wrong then... cough.
jensenmann said:Regarding hum: is your 1084 placed near the PSU? If so move it to the slot farest from the PSU. Try to shield the inductors with some brass (iron! not aluminium, not copper).
Thanks DMP, I will try that on the RV4dmp said:This is my understanding:
RV4 sets the level of the EQ. It's purpose is to match the signal level to unity.
So run a signal through the EQ in bypass and observe the level, then engage the EQ and match the level using the trimpot.
RV5 is adjusted to get symmetric clipping. If you cannot see the signal clipping on your scope, then your signal is not high enough. Since you are using a signal from a macbook pro it is not surprising that you cannot clip the EQN. You need a signal of several volts to get a Neve circuit to clip.
peter purpose said:They are 0.5" pitch... so anything with a smaller body than that will do you.
