shabtek
are you using the dcdc converter or 51x
peter purpose said:I have no idea what's going on here boys.
I checked my records and I only ordered the same ceramics as you from digikey - the tants I got from mouser. Since the ceramics aren't polarized I doubt that is it.@dmp: Going back in the thread, it seems you maybe got same parts as me concerning the ceramic and tantalum links i've posted some time ago reply#175
Maybe some bad tantalums we got?
I terminated the input to the EQN module with a smallish resistor I had lying around and listened again to the output. Even back in the 51X jig the noise was still there.
The noise didn't seem to change much regardless of frequency switch postitions. But it did, of course, disappear when the EQ IN switch was switched OUT.
Pulling out the BA284 amps one at a time saw the noise disappear. Having located the offending amplifier board I thought about what might be causing such a popcorn noise. After giving the board a good clean I removed the transistors and found there was one particularly noisy one. Problem solved.
zayance said:Allright, found the bad amp, changed the transistors on it (all the rest was ok), problem solved....
zayance said:flabbergasting
atticmike said:can anybody tell me what the eq is based on?
zayance said:atticmike said:can anybody tell me what the eq is based on?
Brrr.. wrong question![]()
