peter purpose
Did someone say something?
Hi mate, the dreaded callibration processShandonSound said:if I try to boost the gain as suggested on the other thread it ceases to look anything like a symmetrical sine wave.
ShandonSound said:Thanks for the reply.
I found I'd made a stupid mistake with terminating the input transformer but that is now sorted so my earlier post is probably best ignored for now.
I am a bit confused about J1 though, the scant references I have found to it are a bit confusing to me. I have now shorted across the three pins and have something which sounds much more like full range audio, is this the right thing to do?
Assuming J1 is now correct I seem to have a surprising drop in level when putting signal through the EQN. Is this just a question of calibrating RV4 & 5 correctly? Do both of these affect level as only RV4 seems to make any difference at the moment?
canidoit said:Do you have access to a preamp?
ShandonSound said:any suggestions where I should look next?
ShandonSound said:canidoit said:Do you have access to a preamp?
Thanks for your replies!
Yes I have preamps, I've tried patching in a Sound Skulptor MP73 to boost the level. I have uploaded some screen grabs here:
https://www.dropbox.com/gallery/937959/1/Laz%20EQN?h=e2241f
Which shows the test osc going out of Logic (in the red) and into Spectre on input one (via the EQN). In the first image I have a sine wave which looks something like yours on your journey thread, but then in the second I have upped the level from the preamp and I lose any recognisable sine wave shape.
Do the relative levels going out of Logic and into Spectre look right or is something very wrong? I still can't get RV5 to have any effect on the shape of the wave?
peter purpose said:What you could do is inject signal into the neg leg of c48 to rule out the output section.
Try the same (in to out) with each upright amp.
I am presuming that injecting means the following. On an audio output of a TS output jack, there is the positive, which is the tip. I think it means hooking that tip up to the leg of whatever? As for the sleeve of the TS output jack, I think you would connect that to where it usually be connect to, like the output sleev socket of the unit.ShandonSound said:peter purpose said:What you could do is inject signal into the neg leg of c48 to rule out the output section.
Peter, I'm afraid I have no idea how I would go about injecting a signal!
Looks like I'm out of my depth, probably have been for some time actually, I've just been lucky and tenacious!
I strongly suspect it's a fault/mistake rather than calibration but I don't want to impose on anyone's good will any longer.
If there is anyone out there that might be able to help me fix this I would be very happy to pay for your time and expertise, or if anyone can suggest someone to help (preferably UK based) I would be glad if you would PM me.
Thanks for all the help you have tried to give, I shall have a crack at my second channel and see if that reveals anything about the first!
canidoit said:I am presuming that injecting means the following. On an audio output of a TS output jack, there is the positive, which is the tip. I think it means hooking that tip up to the leg of whatever? As for the sleeve of the TS output jack, I think you would connect that to where it usually be connect to, like the output sleev socket of the unit.
## before you do this, please wait for a confirmation from someone who knows more. I am just presuming here.![]()
