Marcocet
awesome. Thanks!
-marc alan
-marc alan
peter purpose said:I'll get an abortion of a schematic up...... I've been avoiding it like the plague.
Brizco said:i still dont know how to attach the pins to the grayhills...
setup for sw6 (example): front view, one pin attached most northern, then turning the switch ccw and then attaching the second pin most southern.
is this the correct?
briomusic said:peter, just wondering if you had a chance to draw up a schem? especially everything outside of this:
I am trying to figure out a way to go into the EQ directly from an EZ1290......
Sort of. Have you read the instructions that come with the switch?
I'll stick up a pic of pin positions when my camera is charged.
djn111 said:Hi,
About the pin position of the switch take a resistor, and try all holes one by one till you got the action of the switch you need, only twelve holes, so the job is not to time consuming.
DJN
peter purpose said:Very rough schem, but should help.
peter purpose said:My camera is bolloxed, so with the switch in anything but position 1..... put a pin in 12 o'clock.
This is the start point fully counter clockwise.
Then depending on how many positions.. i.e. 5... stick the pin in at 5 o'clock.
Making sense?
