efinque
- Joined
- Jan 3, 2018
- Messages
- 368
The optocompressor/gate I built is very similar but it substitutes the transistorised (discrete) circuitry with a microcontroller.. basically when the signal peaks at a given threshold it turns on a light (LED, incandescent light bulb etc) to which the gain reduction circuitry LDR responds by lowering the series resistance.
So you'd only find a way to inverse the optocoupler LED/light operation so it turns off instead (which increases the resistance during peaks resulting in gain reduction) but it means the optocoupler light is on most of the time (ie. you need to service it more often)
As to how you do it with TTL (transistor-transistor logic) is another thing.. basically a logic NOT gate, you could also try a (solid-state) relay to open the circuit I think but it isn't much of an envelope follower then, like someone said you could shunt current from it to ground too I guess.
Modern LDRs from 150kOhm to 5kOhm were about the widest I found which are probably ok for line level signals (~1,2Vrms)
