lead poisoning usually takes place by 2 am so i have to quit,
using the old kester 60/40 rosin core, thick, low melting point, have to re adjust solder method otherwise you get flooded tube sockets,
only way to clear a flooded pin is to heat up the solder inside and hit it quick with some contack cleaner, hold you breath, i do not know what henious chemicals are formed when contact cleaner hits a hot soldering iron, but it can't be good, one of the cans at radio shack was only 1/4 full, i asked the cash register guy who was huffin the cleaner and he gave me the stank eye so i left and did a quick hit off the new can in the parking lot, hey jus kidin,
GE 12BH&a came in, looks like a good match, almost the same code,
will pick up a JJ 34 thanks for that Volker!
oh, one trick for soldering with low temp solder is to put a junk tube in the 9 pin tube socket while you solder, this will heat sink the pin which means the solder will not flow down the pin as quickly and also the pins will block the solder and will not stick,
another good thing about the ground bus is that you can lay the heater wires down against the chassis instead of twisting them all over the tops of the tube sockets, those turrets would make that look real ugly anyway, so they sit on the chassis.
