What would they be then?Linux is great for some things, others not so much. Many important applications are non existent in Linux.
Yes, very limited linux driver support for the usb audio converters.DAW software like Pro Tools, Cubase, Studio One, Scoring Sibelius, Finale, CAD design Solidworks, Autocad, PCB layout Altium, PADs.
Sure there are sometimes workarounds but often compromised. For example Lynx and RME don't offer supported drivers.
Oh, you mean proprietary stuff. There are plenty of DAW, mechanical and PCB CAD alternatives under Linux. There will always be some vendors who insist on using their own specialised drivers. This is as much a curse as a benefit. For example Focusrite no longer supports early Scarlett products with drivers for Win 10 but they still work with Linux. It is all part of the product lock in scam.DAW software like Pro Tools, Cubase, Studio One, Scoring Sibelius, Finale, CAD design Solidworks, Autocad, PCB layout Altium, PADs.
Not exactly true. Linux will run any class compliant usb convertor and there are very many of those.Yes, very limited linux driver support for the usb audio converters.
I am not sure how much longer ALSA will be around. At the moment you need ALSA, Pulseaudio and probably Jack for any serious audio work on Linux but I understand work is well underway to replace them by a single unified system in the same way that Wayland will replace X-windows.Hmmmm, seems there's more support now than before.
I used to have problems in linux with device settings that are completely software controlled (no associated hardware button/switch).
Does the latest version of ALSA handle that stuff?
Yes, I already have one. I had a smaller one for many years but it is underpowered for CAD work. The newer one has an Intel chip and Linux i(debian) s easily enabled but the screen it too small for CAD workHave you considered a Chromebook with a Linux distro?
I mostly use LInux too. I have been since the 90s. My workshop tower at the bottom of the garden runs Ubunbtu and is great for everything I need. Even the few Windows programs I use run fine under wine. If I could get a fanless OS free laptop of reasonable power I would just stick Ubuntu on it but most laptops I have seen come with Windows - unless you know otherwise.I know you are looking for a Windows 10 computer, but I use nothing but Linux and have very few issues getting things done. What program do you especially need to run on Windows? You seem to be familiar with Linux and the graphics end of it seems pretty solid to me.
No argument there.Personally, I can't stand Windows. I jumped ship after XP and have not regretted it once - except for midi sysex. Haven't found a good way to do it on Linux and every once in a great while I need to do a patch dump while working on a vintage synth
My main CAD tools are Front Panel Designer, Kicad and QCAD, all of which have Linux native versions. I also use freePCB and LTspice both of which run fine with wine.Hi Ian
I am curious what you are using for CAD work - it's probably the Achilles heel of Linux and why you are looking for a Windows machine. I used to do a lot of drafting work with AutoCAD but was also on Windows at the time. I have since stopped doing large CAD projects and have found work-arounds to create the drawings I need. I have looked a little at CAD on Linux but since I don't need it, I haven't really investigated.
I use VNC to remote from my old laptop running Kali linux into my home windows desktop.Ian would it be possible for you to use any old machine and use a remote desktop app to connect to your desktop where you could run the CAD prog from?
Joey
CAD: I use FreeCAD for designing parts and sketching for CAM, some rapid prototyping via 3D-print and casting. It's a bit of a learning curve though (I'm not trained in CAD).
