On the ez1073-500 the virtual ground is at -16v... just a single 8v regulator on the +16v... the Schematic will be in the colourbook..... Gustav will do the PCB's, Grand Master will do the faceplates... AML will do a "partial kit" of the difficult parts.....
"Haima" seems to have answered the EQ questions already..... but just to re-confirm.... the HF is at 12k, the Bottom left is the HPF, the switch above it is phase..... It is clearer on the "real" metalwork as it has the EQ symbols/legends printed on it (they were missing off the lash-up by mistake)....
The second revision of the ez1073-500 should be here today... it is easier to build as the op-amp sub cards are now part of the main card.... the "real" faceplate should be done shortly so you will be able to see what they actually look like... grey with white text.
Still waiting for the mains transformer for the ez1073 so it is on hold at the moment (the custom core for the transformer arrived but was 160mm diameter instead of 60mm).
Colin
www.audiomaintenance.com
