Darkhyrys
Active member
Issue fixed ! ... Thanks Martin
Darkhyrys said:I'm a newbie so could you tell, for exemple what TYPE of resistor, what POWER RATING and what TOLERANCE? Because Mouser for exemple gives thousand references![]()
Darkhyrys said:Hi again,
It's writted on the BOm that we need 2 x 0,2 uf and 2 x 0,47 uf in the low filter section. But on the layer, I only see one of each. What am I missing?
Darkhyrys said:ok, same thing with the 0,22uf in the mid filter section.
you write on the BOM we need a 0,33uf/200V cap for the power supply but it's writted 0,3uf on the layer.
AusTex64 said:Hi Martin,
I'm trying to find a proper Switchcraft 4PDT switch that's latching, like the one you used and is depicted in the layout drawing. Do you have a model number of the one used on MEQ-5? I have a couple of DPST Televers suitable for EQP-1A, but they won't work here. :-(
Thank you!
AusTex64 said:Did some research and figured out Switchcraft Telever 160012 should work. 4 pole, double throw. Martin, is this what you used? Thanks.
Knotty said:you know, I just got to thinking. I've built(Drip) and worked on pultecs before. But i've never opened one of the filter boxes. How is that stuff all stuffed in there? How is it all arranged?
