I just uploaded V0.7 of the Classic Solo Build Instructions. The only change is to add the TL783 and the 1N4007 diodes to the BOM. I will leave V0.6 up there for a bit as well.
ruffrecords said:ding said:I am not going to go this route since I have a 250-250 transformer I will probably use but just in case someone wants this I drew it up. It might be more confusing than what Ian drew up but some people might think this way.
BTW Ian, I got my mouser cart today and even though you clearly have it in the schematic I somehow missed it since it wasnt in the miscellaneous BOM table and didn't get the TL783 or the 1N4007s. Might want to include it for distracted people like me.
I just noticed a couple of errors. R22 is not fitted but is not coloured red in your drawing. Also I forget to list R26 as not fitted which you DID colour in red!! So if you would just tweak your drawing to colour in R22 red I will incorporate it into the duo doc.
ding said:No problem.
EDIT: Here it is. You also forgot C15. Let me know if you need it in a larger size or higher dpi.
ruffrecords said:ding said:No problem.
You lost me. What did I forget about C15?
ding said:ruffrecords said:ding said:No problem.
Sorry, in the picture you crossed out C15 on board #2 but you don't mention it in the docs. I mention it on my image.
ding said:I went a little nuts with FPD and my imaginationI imagine there is very little chance of powering 2 PMTMGU with this unless I get an HT250. Got to stop myself and K.I.S.S. I might just build a separate REDD or Helios instead of this monstrosity. ;D
ruffrecords said:ding said:I went a little nuts with FPD and my imaginationI imagine there is very little chance of powering 2 PMTMGU with this unless I get an HT250. Got to stop myself and K.I.S.S. I might just build a separate REDD or Helios instead of this monstrosity. ;D
If you are prepared to sacrifice a little gain you can use a passive EQ like he REDD or Helios with the Classic Solo and nothing lese. Check out the build document for details.
ruffrecords said:I have been giving this some further thought, especially with a view to minimising the loss of gain by using a passive EQ and, as usual keeping costs low. Looking through some old stuff I picked up during my time at Neve I came across and article about the component parts of a mixer from 1971. it is all semiconductor stuff but it includes a simple passive two band EQ with a 6dB insertion loss (see bottom left hand corner of the attached image). It is interesting because:
1. It provides 6dB shelving boost
2. HPF/LPF style cut (no shelving)
3. Provides boost and cut with one pot
4. Can be extended to include a bell shaped mid boost/cut
5. Uses cheap linear pots
6. Could be modified to make a more ambitious/flexible EQ
The values would probably need to be modified to make it properly compatible with the Classic Solo.
ding said:I would be very interested to see how this 6dB eq turns out. I would love to discuss it in a design thread. Looks very interesting. Thanks so much Ian.
BTW I'm patiently waiting for your compressor design. I know you have a lot going on but is there an idea/design thread for it around?
ruffrecords said:I have decided to order 10 custom mains toroids. I can use two myself and I have commitments for 3 more. If you want one let me know. Cost is £22 plus shipping and Paypal fees.
ding said:Have you tried tightly twisted wires right up to the tube pins? Are you going to feed the heater elevation into the humdinger?
ding said:Ian,
Any thought on a dc supply for this? I can veroboard one. Any schematics you've used for your previous projects? Best way to wire it to the board?
ding said:been looking at simple dc heater supplies for my edification and I found something curious in this article.
http://www.r-type.org/articles/art-124.htm
The article suggests coupling the dc terminals to chassis thru a couple of .5u caps to remove modulation hum in certain cases. Any thoughts? Overcautious? Should the caps short then...what? I guess this is like creating a "center tap" but with caps instead of resistors.
