kosi said:Hi Ian,
would a Carnhill gapped VTB2290 work as OT ?
thanks
ruffrecords said:the levels of hum I am measuring are very low. Typically 1mV at the output of an amplifier with 70dB of gain so referred to the input the hum level is about 0.3uV. and that is with AC heaters.
ding said:I would be curious to know what the FFT would look like with AC heaters and the HT rectifier away from the main board. But I guess you can just measure your Classic board for that info since the power supply is separate.
kosi said:Slowly reaching the finish line !
I cannot find the value of R1 from the 4toggle pcb, either I have tomatoes on my eyes or it's simply not there.
ELM said:Hi there people, my first post!
I'm one of the happy lo hum testers.
I'd just like to ad that i love the sound of this preamp! It has the sound I was looking for.
The small hum i have left in my prototype box is probably caused by badly layed out grounding and messy un shielded cables. The hum changes when i move things around. When i short pin 2 and 3 Its very quiet!
One thing that exites me about the sound is that dynamic/ribbon mics comes to life in a way that I didn't expected.
Thanks a lot Ian!
ELM said:Since I have the mains transformers I'm thinking of maybe rack 4 solo pcbs but then put the 4 mains transformers in a separate enclosure, just to keep the hum down.
Is there any disadvantages with that solution?
ejendres said:hey Ruff, I'm working on my Lo Hum build. I'm doing a dual mono setup using a single mains transformer. Reading through the documentation for Dual build i see it was written for the original circuit. In particular am I curious about how to handle the high wattage resistors R21-R25. I assume I handle R21-24 as described in the documentation and then treat the variable resistor as R25. Is this correct?
ELM said:Are the lo hum pcbs coming? I need more of those![]()
