Thanks very much, Ian! That was my instinct, but my instincts have led me to do some pretty strange things in the past, so I thought it best to check.
-Clint
-Clint
I just checked the PCB layout and I can confirm those are the correct values.Hi,
On the new 4Toggle pcb, it looks like the resistor designations have changed a bit from ClassicSoloLoHumBuildInstructionsV0.2. Just to be sure I have it right, it looks like:
R1,2: 6K8
R3: 150
R 4,5: 680
R6: 3K3
R7: 150
R8: 3K3
Is that about right?
Clint
Absolutely! I’ll do a couple shots with my real camera and email them to you.I am glad you like it. My friend Pierre hosts an independent gallery of people's projects built from my designs. If you would like to send me a few pics of your build I can pass them on to him to incLude in his gallery:
EzGallery
I had no recollection of that so I had to go and look at the PCB. It is on the mic, line and out Molex 3 pin connectors. It was probably meant to indicate hot but it is in the wrong place for that. My 'standard for 3 pin Molex connectors carrying balanced signals is pin1 screen, pin 2 hot and pin 3 cold, just like an XLR. I always make pin 1 of a connector have a square pad, the the H's are beside pin 3 which is wrong. So best just ignore it. (I may have added them as a visual aid when tracking the PCB to make sue the did not get swapped between input and output).I'm going to be done with this soon. What does the "H"s mean on the toggle PCB?
Aha! I’ve been scratching my head about why my tube mic was out of phase to the others. Easiest fix everI had no recollection of that so I had to go and look at the PCB. It is on the mic, line and out Molex 3 pin connectors. It was probably meant to indicate hot but it is in the wrong place for that. My 'standard for 3 pin Molex connectors carrying balanced signals is pin1 screen, pin 2 hot and pin 3 cold, just like an XLR. I always make pin 1 of a connector have a square pad, the the H's are beside pin 3 which is wrong. So best just ignore it. (I may have added them as a visual aid when tracking the PCB to make sue the did not get swapped between input and output).
It's open.When you say the output transformer has no resistance across the primaries do you mean it is open circuit or short circuit??
