Walrus
Have you linked J4 to J5 on the bottom of the pcb, as there isn’t a link on the top?
They are for DI use but if you don't have a DI you need to link them. I am pleased you got it working. My friend Pierre hosts an independent gallery projects that people have completed based on my designs:TillM said:Hi Kevin,
no I don’t.
Do it after reading your post and now it works.
Good damn.
I thinked about, but also thought, they are just for DI-Use.
Thank you very much !
TillM said:Hi Ian,
I want to use a DI, but I linked the DI to the toogle board to the line molex.
So I hope, I did not something wrong.
Till
mgb54 said:I'll start to put a pair of these together soon! Has anyone experimented with adding an LED to show when phantom is active?
Depends what you mean by active. The usual method is just to connect the LED via a suitable series resistor (10K should work for many LEDs) to the switch that turns on the phantom power so when phantom is turned on the LED comes on too. I do not recall the total current the Classic Solo power supply can provide from the phantom supply but I do not expect an extra 5mA would worry it too much.mgb54 said:I'll start to put a pair of these together soon! Has anyone experimented with adding an LED to show when phantom is active?
Hi Ian, this indeed worked a treat, low-current LED with 10k in series to the switch. Thanks.Depends what you mean by active. The usual method is just to connect the LED via a suitable series resistor (10K should work for many LEDs) to the switch that turns on the phantom power so when phantom is turned on the LED comes on too. I do not recall the total current the Classic Solo power supply can provide from the phantom supply but I do not expect an extra 5mA would worry it too much.
OK, and at that time what is the voltage at the 48V pad on the Classic Solo PCB?So, when I disconnect the 48v cable from the toggle board I get -0,04vdc at the 48v pin.
Register today and take advantage of membership benefits.
