Feeler: Classic Solo
Well done. Very neat build. Is it OK if I pass the pics to Pierre who keeps an independent gallery of builds based on my designs?
Hi Ian,
I am currently collecting information for a future two channel Pultec build. I have all the info I need about the passive EQ section, and am now venturing into tube gain makeup territory. This would be my first tube project. I do have some experience with other DIY builds, including modifying them, but in this case I am a bit out of my depth. I hope you don't mind if I ask some questions that might have been answered before - I have read pages upon pages in both the Pultec and Classic Solo threads and have not found the definitive answers I am looking for.
Apparently it is possible to use a Classic Solo PCB as a PSU and Gain Make Up solution for a two channel Pultec EQ build (instead of two PMTGMU boards and a separate PSU board). I am a fan of less PCBs to mount, so this sounds apealing. I have examined the Classic Solo PCB layout and schematic in the documentation and my intuition says I need to look at the Dual DI setup to achieve this.
For reference: I am looking to use Carnhill VTB9071 10K/10K input transformers and Carnhill VTB2291 600/600 output transformers, as derived from the Pultec documentation.
The Classic Solo documentation describes a modification of using the 6922 in an SRPP configuration instead of a MU follower configuration. From what I read, SRPP has lower gain than MU follower and SRPP produces more distortion before it starts clipping, whereas MU follower has more gain by default but clips earlier. Does the lower gain of the SRPP configuration even matter if the Classic Solo is used as a Gain Make Up stage for a Pultec EQ? The behaviour of the SRPP (more distortion before clipping) sounds desirable somehow.
It would be nice to be able to dial in (extra) coloration. If I look at the schematic of the Single DI configuration, this is done by feeding the signal through the second tube and using a 10K LOG pot as a gain control (I guess you could call this "drive" control?). I think this would mean that a second Classic Solo PCB is needed for a two channel Pultec EQ (and thus twice the tubes and other components, minus one PSU section). The driven signal is attenuated by a 1K LOG potentiometer. Would the extra attenuator be needed if only on tube stage per channel is used (thus no "drive" control)?
Best regards, Alex
HI Alex,
The classic solo will work fine as a gain make up amplifier for a Putlec EQ. You need at most 20dB of gain for this and both the SRPP and Mu Follower versions have more gain than this.
You are right in thinking you can obtain a lot of colouration by adding another SRPP stage and driving it hard and then attenuating the output. And it will need an extra classic solo board.
The big question is how much colour do you need. The SRPP has just enough gain to make up the EQ loss and the 6dB loss in the output transformer with a little to spare so under normal conditions it will be working at around your nominal line level (typically +4dBu). The distortion in an SRPP is directly proportional to output level and is typically 3.5% at a level of +20dBu falling to about 0.35% at 0dBu so there is already a nice bit of colouration at normal operating levels. The easiest way to add more colur is to simply overdrive the EQ input and add the 1K [ot across the SRPP's transformer secondary to restore normal operating level.
Hi Ian,
so in practice, just feed a hotter signal into the box for more colour.
The attenuator; I assume that would be a dual gang 1K LOG pot like depicted on page 13, but instead of using it as a pad on the input transformer, it would be connected in the same way on the output transformer? The schematic on page 13 also shows resistor R3 of 68 Ohm, would an additional resistor also be necessary in this application? If so, what value would be best?
Cheers, Alex
Hi Ian,
Yes, that is right
Cheers, Alex
I am not sure which page 13 you are referring to. Can you please clarify?
Edit: I just realised which page 13 you are referring to - the build instructions. Page 13 show a variable mic input pad whereas what you need is a variable output pad. Two versions of a suitable circuit are shown on page 23 but these days I just use a straightforward 1K LOG pot wired across the output transformer secondary.
Yes, that is right
Thank you for the explanation Ian, and apologies; I could have been clearer with my question.
The output pad on page 23 of the build manual looks simple enough, it's just a dual gang LOG pot. Since this pot attenuates the balanced signal I assume this one comes after the output transformer, thus giving the option of running the entire unit hotter including both transformers? If so, it keeps getting better and better :) .
I haven't been able to find the PCB files for the Classic Solo Lo Hum on your site, and the PCB shows on stock even though the page says that the table was last updates in may 2021. Does this mean I can buy one from you? If so I will send you an email, as instructed on the page.
Cheers, Alex
