OPA Alice in a split config for upright bass mic?
I'm assuming the electrolytic is C3? ..... in which case yes, it can be rated at 25v.
I see you've corrected the schematic, to connect R1 to the half rail (which you call 'VGND' ).
The op amp connections are still wrong.... As Voyager10 pointed out in post #6:
•The capsule /R1 junction should be connected to pin 3, and not pin 2.
• Pins 1 and 2 are connected together.... Not 1 and 3 as you have at the moment.
Thanks. I'll get the OpAmp connections updated soon!
Ok. Fixed pins 2 and 3 and also the GND connection on the opamp. Thanks for catching that! This also has the capsules ground connected to circuit ground and not VGND. Hopefully this is at least the right circuit. These would be teeny boards!3D_Body PCB_2025-02-21.png3D_Capsule PCB_2025-02-21.pngSCH_OPA Alice Body Board_1-P1_2025-02-21.pngSCH_OPA Alice Capsule Board_1-P1_2025-02-21.png
Ok, so I renamed C3 to C2. C3 is now on the body board.
R4 and R5 are now 1M and C2 is a 1uF MLCC. Does it matter that C2 is not polarized in this case (since it replaced a 47uF polarized electrolytic cap)?
The capsule board is 14.5 x 14.5 mm. The body board is 20 x 44 mm.
Speaking of GND and VGND, should the ring around the capsule connect to GND or VGND?
See my post #7. I would propose to connect it to Vgnd.
The idea behind this is that the OPA circuit amplifies the signal between its input node (pin 3) and its AC reference node, which is Vgnd. Ideally, C2 shorts Vgnd to GND for AC signals and there should be no difference, but as C2 has to be X7R at this value, capacitor microphonics and piezo voltages would add up to the capsule signal. To avoid that, connect capsule chassis (= capsule ground) to Vgnd. Any voltage on Vgnd caused by said microphonics or piezo effect will appear as common mode voltage on your preamp input and will for the most part be rejected.
Jan
