Awe look........the little baby's all grown up
First board worked on the first try. I'm waiting for a couple of parts to come in tuesday to finish the other channel for stereo linkage. It was really easy to build. Board only took a few hours to stuff (with no BOM mind you haha). I don't have an original to compare to, but first impressions: sounds sooooo good it's just silly. Threw a mono lead guitar track on, hit it with about 10db compression - sounded like butter (I couldn't believe it wasn't margarine???). I used all polypro film & mica caps, and an elna silmic cap for the single electrolytic in the audio path. Initial tests were done with two 2N5089's in the audio path (hfe matched), but I'm going to drop in a LM394, MAT02, & MAT12 and do some comparison tests to see if/what the sonic differences are.
Checked against original power transformer, results on sidechain voltage were within 1V with a standard off the shelf toroid. Which means it eliminates the need for the custom power xfmr used on the original.
If anyone wants to play - I could really use some mono vocal/guitar tracks to do some tests with (something that's ok to post on the board). I'll run them through and post the original/compressed versions so we can all critique.
Still have to start the whole RMAA process, but unit is ultra quiet, no hum, etc.
On a somewhat sidenote - today I was reminded the importance of practicing safety when working on electronics, even lower voltage units like this - reality is, it can still kill you. I had the unit powered down, and was cleaning up some wire runs around the toroid/IEC outlet. Although it was powered down, I wasn't thinking about the fact that the IEC outlet still had line voltage on it, because the unit was still plugged in. Well, I was quickly reminded. And so I'll remind all of you so nobody makes the same stupid mistake. Please be safe!
Now, without further ado...here is your porn for the day
