Internauta
Member
- Joined
- Jan 22, 2015
- Messages
- 11
hello,
is there a formula to calculate the Q of an LC filter made with a series ferrite bead + parallel capacitor to ground?
I am trying to add some RF filtering to an AC/AC 15V wall wart output before hitting the rectifier diodes in my linear power supply, but I fear to create more troubles than improvements if I miss the right inductance..
here is attached a schematic from Rane with a very similar circuit. How can I select the proper ferrite ?
Could be more effective the use of a common mode choke instead of the ferrites in this case?
thanks!!
thanks!!
