fucanay
[quote author="Samuel Groner"]With respect to the hum problem: if it's the same in both channels it is likely that there's too much ripple on the supply line. If it's more in the channel closer to the PSU it's probably rather just induced hum. Try rotating the transformer as a first means.
Samuel[/quote]
It's the same on both channel according to the analyzer I use in Logic. Both channels have noise at about -55db at the lowest gain setting, then during the rotation it gets a small amount better before getting really bad.
I tried rotating, putting it outside the case, and another transformer and performance is the same. I put the PSU board up bout 5 inches outside the case sitting on a cardboard box. I tried putting another 1000uf cap after the regulator. I still don't know how to use my scope, nor do I have proper probes, so I don't know how I'll find out about ripple at this point.
Grrrrrr.
Matt
Samuel[/quote]
Grrrrrr.
Matt
