maxheadroom
i had the same problem as you described in the first sound sample.
The output impedance of the voltage follower is a function 47K resistor on the base of the ZTX653. If this resistor is too big, the output will not have enough drive and will be clipped on one 1/2 of the waveform. On the opposite end of the spectrum, if you make it too small. More power will be dissipated than needed in the output devices. The value shown provides adequate drive for typical line inputs, with or without the 1:1 output transformer.
