first DIY project suggestions.
ze marcelo
Member
Brazil
Hello everyone, I'm planning to build my first DIY project and I'm thinking about the Gates M-3638 -SA-134 octal tube preamp, it seems affordable for beginners like me. however I would like to hear from more experienced people before starting the actual project. Do you think it's a real starting point? If not, could you suggest another tube preamp project? I'm open to any suggestions, thank you very much.
Have you done anything with electronics (guitar amp repair, etc)? If not, I would not start with a tube project for my first - the voltages can be lethal unless you know what you’re doing.
If you have 500 series, one of the many preamp kits available is a great first start, since the power supply is taken care of for you. Something like the CAPI VP26
+1
I find the old Gates units very interesting, although I think the Gates SA70 would be the better choice as it has less gain, easier to build and there are also some proven mods for it described here in the forum.
a good cheap and easy mic pre project is the DIYRE 500 series Colour preamp, even if you don't use any Colour modules. Very nice clean preamp with THAT ICs right off the datasheet -- very hard to mess up: https://www.diyrecordingequipment.com/products/cp5-mic-preamp-with-colour
Five Fish Audio also makes what I've heard is a very good cheap 500 series mic pre kit, but I am not as familiar with it: https://www.fivefishstudios.com/500serieskits/sk1di/
like @Dylan W said, tube stuff isn't a great move if you've never worked with tube equipment before. A better path to learn your way around tube gear (rather than a pro audio piece) could be something like a 5E3 Tweed Deluxe or 5F1 Tweed Champ guitar amp kit.
What does that 'Color' knob actually do?
"As much as you want of any color" - how's that possible with a single knob?
It’s a modular system, there are different line level “plugin” modules that go after the preamp. When you turn the color knob, it turns up the input and turns down the output. Pretty clever and some of the modules are pretty nice sounding.
Hi everyone, thanks for your quick response. @Dylan W @z11111 , I already have some experience with residential electricity (installation, modification and minor repairs) and also with electronic devices such as guitar tube amplifiers and hi fi tube amplifiers. At the same time, I have installed in my house a Residual Differential Device that allows you to avoid any electrical shock. I also thought about DIY 500 serie, but unfortunately I don't have a 500 series rack and it´s very expensive for me import one of that in Brazil. Very nice project @rock soderstrom, maybe it will be my first one.
+1
Hi @rock soderstrom I have a friend who is going to build the transformers for this project, but I need the measurements of different transformers, would you have that? Thanks in advance.
Hi!
No, I can't really help with that. The original Gates SA70 had 50-500:50K at the input and 15K:500-50 at the output, which means you need 1:10 at the input and approx. 5:1 at the output.
The output transformer is without gap.
That's all I can tell you... :cool:
Olá José,
como está você?
Cumprimentos de Portugal, seja Benvindo a este forum
Like other fellows wrote I also don't think that's a good first project.
What is you line of work? what do you do in audio?
What are your personal needs in terms of equipment?
Grande Abraço
Olá José,
como está você?
Grande Abraço
obrigado pela gentileza das boas vindas, espero que o outono esteja lindo em Portugal.
I work as an audio engineer at the Federal University of Paraíba at the same time as I have a project to set up my own recording studio. I already have some equipment but I would like to have a little more in my setup. Currently the dollar is very valued in relation to the Brazilian real, which makes it very expensive for me to buy American or European devices. So, I decided to build my own. I certainly don't have much experience in electronics, I'm studying a lot about it, however I have an electrical engineer friend (https://alstechvalvulados.blogspot.com/) who gives me all the support in this project.
All the best
