First linear PSU troubleshoot help
Thanks guys!
Have not tried yet the modified wiring, but Im almost 100% that it is the correct one.
On the other hands, Ive asked the supplier for a specification
Tried and works like a charm.
I have another question, regarding the grounding.
I've connected the AC Inputs Earth to the chassis, but should I connect the PSU boards ground there as well?
home_listening said:
I don't see anything on the product website to indicate you should tie the two black wires together. Check the phase of the secondaries (all 4 disconnected) with a scope. If each secondary winding has its own colour then you would need to tie a green and a black together for the CT.
This.
