I'm hoping some kind soul can point out any major errors I've made, or improvements I can make to the idea I've drawn up so far.
I've been thinking about making a ribbon mic for a while - I've seen some YouTube videos, and figured they seem simple enough (famous last words...).
I'm not looking for insane quality, so much as making something myself, and having a sort of platform I can start with to play with. I figured I'd start with something vaguely similar to the RCA-44.
I have the Neodymium magnets in light grey, and a steel magnetic shield in the darker grey on the outside
I figured I'd design the upper half using stacked plates separated by spacers - and with cut plywood with spacers -- something like this case:
Then I'd fill the (non ribbon motor parts) with low density A/B foam (and cut holes with a hot wire where needed). That would give me a solid, strong, lightweight sandwich that's hopefully resistant to ringing - which seems (to my ignorance) like a fairly good idea. Worst case, I can use a little bit of CLD material to absorb vibrations.
I know I have a lot of reading to do - I'm working on it...
- The ribbon itself would be a tad bigger than the Original RCA-44, 63.5 mm (2.5") long and 4.7 mm (0.185") wide.
- The YouTube video linked also points to this 0.4 µm Aluminum leaf - I could use it, but I'm find with using something different.
- I know geistnote sells various thicknesses.
- I could follow the formula in the video for the ribbon size/thickness & transformer -- but I'm open to suggestion.
- At this point, I'd prefer inexpensive, with the idea being that I know I'll be replacing it in the future (after I've learned more.)
