Well it seems to work, well...sort of...
I have used shielded cable on the 5 pin connectors. The shield is terminated to ground at the nearby TRS connector. However, on the very last gain setting on the right channel, there is extreme oscialltion.
I know this isnt a new problem ,so what other solutions besides shielded cable have others come up with for this ?
Also. is it normal that I should get a signal through the instrument jack when the selector is set to MIC. ?
Thanks in advance...
