TL;DR -> Does this schematic appear to fit the need of switchable 10db/20db attenuation targeting an output impedance of 11.2k?
Well, been lurking for a bit but outside of very minimal mods and plenty of cable construction I'm about as green as they come. So I'm starting simple.
I'm looking to create an attenuation box that will take DB25 in from my True Precision 8, have switchable 10db/20db attenuation for each channel, then back out over DB25 to my interface (Antelope Zen Studio+).
While I couldn't find input impedance for the Zen Studio, I did find the Orion from the same time frame is 11.2k and I'd be surprised if the ZS+ isn't the same or close. So that's the figure I'm working with. The output impedance has been prioritized, but fwiw the input is 100 Ω.
I've spent a good bit of time on the Uneeda Audio "All About Pads" page and worked through a bunch of match to get to a combo that I *think* does what I want in terms of the circuit of one channel. The schematic itself is from the L2P with R values updated to reflect where I ended up with my calculations.
So as a sanity check, does this even look like it's in the ballpark of what I'm aiming for? It's highly likely I have misinterpreted things at some point, so just want to check before I go any further with the design.
