Upacesky
I bought those projects as a whole package. I'll not finish them as I'm in a 500/51X trip at the moment.
They are mostly stuffed (not from me), I'll describe the main missing parts on each board.
Disclaimer: the soldering is a bit sloppy, the jumpers were not made "state of the art", well the boards are not "nice". None has been tested. That's why I sell them cheap.
On the other hand, with only a few components, you have a working unit... 8)
FiveFish SC1: stuffed, ICs & pot (bourns) and switch (grayhill) provided. Some oxydation on the in/output pads. Need a dpdt switch and a LED for the phantom power.
40€
Fivefish Vu1 meter module: Fully stuffed, 5 LEDs. Traces of oxydation on some pads.
5€ or 3€ with the SC1.
Nite EQ V2 (only 1 channel): mostly stuffed, missing the pots though. You need to check the output for balanced/unbalanced operation. Some oxydation on the underside. Hook a power supply, some pots and you have a really nice EQ.
20€
GSSL: older revision from Gyraf board: mostly stuffed, you need to provide all the electrolytic caps, DBX2150A already soldered, control board with lorlin switches, ICs, wires and pots provided.
12€
GSSL Super Sidechain: Stuffed, clean soldered, should work as expected.
25€
Pico Meter 18: Fully stuffed, 9 blue LEDs. Traces of oxydation on the LEDs' legs. Should work as expected
5€
Pictures: https://drive.google.com/folderview?id=0B7K5U7XZzfScTTE5Z2xvOUJidVE&usp=sharing
All items shipping from Germany
40€
20€
12€
25€
5€
