One of the line outs has died on my 2i2. iO got it cheap back in 2017 and it was always a bit flaky. Headphone out on same side died too. Are these easy/worth fixing?
My Gen3 works on linux also.It is Gen 2. I only got it because I updated Windows and my Gen 1 was no longer supported which is why I bought a B stock Gen2.
At least the Gen1 still works with Linux.
ian
Cool. I will definitely check that out.For what it's worth, i did a teardown and documenting of the more important silicon in a gen1 2i2, as well as gen1 and gen2 2i4 on my blog, in case it's any help..?
Can also confirm that my 2i2 Gen 3 is plug-and-play under Linux. No additional drivers are required for Ubuntu.My Gen3 works on linux also.
Significantly quieter? Would love to see some measurements on that.I use the iDefender power injector/ground isolator and an external 5V supply with mine and they become significantly quieter.
I believe that this will improve things. The question is rather, can't we do it ourselves for much less money? Ultimately, only the grounding of the USB line is interrupted and an external power supply is connected. Right?Significantly quieter? Would love to see some measurements on that.
How about neither?
I can run my Scarlett 8i6 off one of these for over 2 hours; don't need to be near an AC outlet, or tax my laptops's battery. A 2i2 should last much longer.
https://www.amazon.com/gp/product/B01M7Z9Z1N/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Improve what? I bet if you test it there is no real improvement, and certainly no audible improvement.I believe that this will improve things. The question is rather, can't we do it ourselves for much less money? Ultimately, only the grounding of the USB line is interrupted and an external power supply is connected. Right?
Okay, we seem to be talking about different things. My experience is that USB powered audio interfaces suffer from the interference of computer hardware. This is not always the case, but quite often, depending on the computer. Chirping, hissing, artifacts to the point of audio dropouts, I have seen it all. With my Steinberg interface you could model the noise with the mouse, almost an instrument.Improve what? I bet if you test it there is no real improvement, and certainly no audible improvement.
I do hear people occasionally talk about these artifacts, but I have never had them. It doesn't mean they don't exist. Do you have any recorded examples?Okay, we seem to be talking about different things. My experience is that USB powered audio interfaces suffer from the interference of computer hardware. This is not always the case, but quite often, depending on the computer. Chirping, hissing, artifacts to the point of audio dropouts, I have seen it all. With my Steinberg interface you could model the noise with the mouse, almost an instrument.
If you disconnect the ground of the USB connection and use an external power supply, everything is quiet again.
For this problem, a separate device genre has been established. Whatever they do, I find this stuff overpriced.
PS: the improvement is clearly audible, no need for measurements
Yes, once again. We are talking about two different topics. I'm not talking about the audiophool nonsense of "sparkling highs" and "abysmal bass" due to exotic power cords and gold-plated fuses. Don't put me in that corner.My problem with the claim that it's audible is that every home hifi enthusiast in the world claims an expensive IEC cable makes their rig sound better. They're absolutely convinced of it. So without objective testing I just file it in the circular bin.
To quote one of our mods:
"Audio technology is quite mature, while human nature remains fallible and susceptible to suggestion."
By "quieter" I mean tonal USB "hash" deep in the noise floor.Significantly quieter? Would love to see some measurements on that.
