Buttachunk,
understood. The reason I'm asking is that when I had my accidental version working with the 5C9 and the amp stradling the feed to the sidechain as your first schematic for the make up amp depicted,I had the option of alot of compression. When I later tested the circuit more like where you are now I found that I was missing a bit of compression that I had dialed in for some of my test material.
keep the good work.
cheers, :guinness: :sam: :sam:
Lance
