You have got it, thanks to nature that it obeys the rules of windowed FFT.Then aren’t you just trading one set of anomalies for another? The amount of proximity effect depends on the capsule construction, i.e., dual diaphragm has reduced proximity effect. It also depends on the incidence direction, e.g. there’s no proximity effect at 90°. I thought quasi-anechoic measurements work by windowing the impulse response before the first reflection?
The claim that cardioids measure better when using a cardioid ref mic is ********, because it holds only true when the polar patterns are identical...
