audiophreak
Hi alexc,
Thanks for the pic . It looks like you have a lot going on there as far as grounding goes.
First off ... I am NO EXPERT - so please take care with voltages and I hope the more experienced will chime in ;D
from the pic it looks like you have 7 ? wires going to a " Star Ground " bolt , then another wire going to another ground bolt on the side panel by the PT ? is this correct ? if it is , that may be one problem - I would scrape the paint off from around the bolt that the 7 wires converge and that becomes the one and only ground point ( assuming I haven't missed anything )
... also , what are the white,red and black wires from the front panel going under the PCBs ?
... another observation , you have 4 relays on the in /out puts for true bypass , and also a " power on " lamp - are you powering all of these from the 12v secondary ? and if yes , what is the amp rating / output of the PT ? two tube heaters, 4 relays , and indicator lamp may be too much of a load ... possibly
... ok , that's all I got , please be careful
and I hope it all works out for you , please post back with your progress
