frazzman
gyraf said:Fabio (Audioman) and frazzman,
We've been through this a couple of times before:
Gain through the GPultec depends on two things:
1 - The actual raw gain of the tube used - this varies some +/- 2½dB on NOS tubes, probably more on new-production ones. You could use Russian 6N23P for slightly more gain in average (if you can find those).
2 - The ratio of the values of hi-boost potentiometer (10KA) and the hi-cut potentiometer (1KA) - this is where we do the actual -20dB no-eq-attenuation (Schematic - http://www.gyraf.dk/gy_pd/pultec/gy_pd_sch.gif )
For adjusting to unity gain, you could probably put a 1K Ohm trimmer potentiometer at the TOP (clockwise end) of the hi-cut pot and adjust for unity at no-hicut-setting. Only side-effect of this will be slightly less available maximum-hi-cut at pot extreme setting.
If you do this, let us know how/if it works - would be nice to have in this thread
Please also note that this circuit was made for LL5402's in and out - other brands of transformers or no-input-transformer may very well give varying results.
Jakob E.
ps: I've had quite a few JJ tubes fail me after short time. Maybe it's poor production standards, maybe they are specified slightly different than real E88CC's, and don't like us going to extremes of cathode/heater potential differences. I use Philips 6922, and like them a lot.
DO NOT run this circuit above +250V HT - the tubes don't like this. Raise series resistor value until you have some 200-250V HT under load (tube heated, ca. 30sec.). A standard 0.6W type resistor will nearly always do fine - you do the math of power dissipated at given resistor and given voltage drop....
Thanks Gyraf for your reply!
I dropped my 3k3 resistor to 22k and now have a healthy HT voltage within the acceptable range.
I still have a about a 6-7db volume drop when the unit is inserted (in bypass and with circuit in).
I always used the lundhals in the past but thought Id give an edcor xs1100 a shot as don-audio had an adaptor board that made it easy. As you said, you didn't design it for this transformer so it probably has something to do with that. Never had an issue when I built with the lundhals in the past.
Anyone had any experience with the edcors on these builds?
I was wondering if the 10k and 2k2 resistors strapped across the input and output connectors should be omitted when not using lundhals?
