2K is fine
managed to get 0dB overall loss when unit is bypassed. But I still have about the same loss between bypassed and active.
gyraf said:miszt - we've discussed this several times before in this thread.
Most part of raw-gain-mismatch comes from tube's gains that vary due to production tolerances (try swapping them)
Most part of bypass/in gain mismatch comes from mismatched ratio ResistanceLowCutPot/ResistanceHiBoostPot
Jakob E.
We match the 6922 on average within 1mA on the Anode and no more than 2mA. This is normally an accepted good match.
You can request a specific specification on ordering and we would take this into consideration before dispatching.
gyraf said:I think we mentioned earlier in this thread that socalled "matching" of small-signal tubes is not worth the paper the figures are written on.
Matching is for power tubes, ensuring approximately the same current vs. grid voltage.
For GPultec you'll want tubes matched for raw gain "Amplification factor" or µ
If you really need matching, the best way is to buy a handful and use the best-matching ones
Jakob E.
febo2609 said:If someone used a coil for G-Pultec eq1 from Don Audio store.
What are the experiences with them.
Is Sowtek coils better than Don audio coil.
Best regards
