I used the big Carnhills for outputs on mine, mounted off the pcb - 2:1 turns stepdown with 2400:600 impedance.
-3dB point is close to 20Hz - no rolloff really at all.
I used Lundahl 1:7 on the inputs, LL1530 I think. It has a higher step up and a larger core.
Used au7 tubes, eh all round. I subbed some nos AV7 in the first position, and I preferred it, but there wasn't much in it, so I stuck with the au7s
What I did find interesting in re-testing my G9, which I built around 2010 or so, was the THD numbers.
In my config, it is quite easy to dial in THD from around 0.3% to 4% or so. ie. quite clean to quite crunchy
- the nfb 'gain switch' and the 'level' pot work very nicely and evenly for this.
I formed the impression from the numbers, that it's 'not as clean as I thought it would be'.
Signal-noise was reasonably good, maxing out at around 86dB of margin from the 'hum floor' (using line inputs) to a max of 1% thd, under a variety of gain/level settings.
I have a little 200Hz hash in there worsening that result by around 2dB to 3dB or so - the 50,100,150Hz hum components were quite a bit lower. I think I could improve that with a bit more jiggery and pokery ...
Next time I open it up, I'll chase down that little hash at 200Hz, and while I'm there, beef up the heater regulator a bit.
I can then safely leave these nice old philco av7 in the first position, which use more heater juice.
Ideally, I'd also change the second position to 6dj8 - I would expect that would clean things up some as well as giving a bit more gain, meaning the 'gain switch' could come down a click or two lowering the overall thd a bit ..
Anyway - I have more experience in tube builds since I did the G9 ... I have found a new respect for the design, after doing the thd measures with 'room eq wizard' app
Getting a decent amount of thd, smoothly variable, and majority 2nd harm, is not always easy to achieve - particularly in a box which caters for mic, line and hiZ inputs ....
Indeed, I
was going to 'recycle' it into some of my current builds, but I ended up keeping it the way it is
Maybe one of the 'younger generation' of 'The Lab' folk will re-layout this design, with some changes ..
Things I did were :
- seperate the line input and mic input connectors
- added a switched relay bypass from line inputs to main outputs
- re-inforce the main ground traces
- offboarded with cable the HiZ connector
- off boarding the heater regulator
- offboarding the +48V section with a JLM 3rail psu module
- modified HV section to use a single psu toroid transformer
and just for kicks, I added a led vu meter for each channel, powered off the JLM 3rail.
If I were doing my 'ideal' tube mic pre, I'd probably choose the G9 front end ...
