D&R has no Phantom.
D&R line level is unbalanced as SM indicates.
All i mean is DIY U87 --> DIY G9 phantom in --> D&R mic in. Using XLR to TRS cable.
Is this safe?
PS. Tiago, you have PM reply to your message.
Forgot to push the post reply button, sorry.I have no PM from you in my inbox, I checked it
The thing that most scares me is if Phantom is an issue.If Phantom Power is not an issue, then you are injecting Line Level into a Mic Level input.
Heh, you're strict as always Mr. It's a sweet little consoleVery strange design; the gain control AFTER the microphone preamp!
(Maybe that is the reason why here in Holland D&R is known as 'Dutch Rubbish'
Why are G9's outs line level?
Rudolph, is it safe to run a custom XLR to TRS cable from G9's out to Dutch Rubbish's mic in?
Nice link, but nobody will be able to reach it, because it is a file on your own PC!file:///C:/Users/User/Downloads/D&R-200Series%20mix.pdf
Most line-level *outputs* expect the input impedance of the device "downstream" to be in the 10-100Kohm range. They might not be too happy (read: likely to distort / clip sooner than normal) when driving a 1-2Kohm impedance (as is quite usual for mic preamps).
Coming from digital world, i was thinking like i do in my Focusrite saffire interface. It has a multi XLR/TRS/TS input and only Line / Instr. Switch. So Line Mode gets both line and mic signals like dynamics (in terms of impedance it's like the mic input in D&R).
Gosh i have been recorded most of my discography so far by the wrong way.
