It's what you might call valve headroom...as in it will gently start to distort in ways that you will probably like, and you are likely to set the levels in such a way as to take advantage of a certain amount of that colouration. Due to the gentle onset of distortion, you can't really pick a signal level that is the maximum that the unit will handle as it all comes down to taste; and without defining the maximum signal level you can't define the headroom. I have never checked the maximum output on my G9's, but I'm sure it will do pro levels without any serious, objectionable distortion. Actually, I do recall it doing 30v peak to peak (low load) on the scope without any visible distortion if I'm not mistaken...
Bjorn
