Did you verify that all transistors are in their proper places and the larger BD's are facing the right direction? I can't really tell from the pic.
jsteiger said:Did you verify that all transistors are in their proper places and the larger BD's are facing the right direction? I can't really tell from the pic.
While checking side by side (good guy and the bad guy)gar381 said:Check post: http://www.groupdiy.com/index.php?topic=33970.msg425092#msg425092
This may help a bit.
As John (Stagefright13) says use a magnifying light for both assembly
and checking your work. My old eyes are so blind I couldn't build
a gar without one. :-[
Most problems are solder bridges on the bottom side
or componet leads touching each other on the componet side.
gar381 said:You can check that the -in millmax pin and the + in millmax pin have no shorts to any of the pads
around them if you like.
GARY
