Hallo everybody, I need some help
Yesterday one of my CAPI 312 almost went on fire!!! :'( :'( I had 2 VP28 in the first slots, two 312 and a LC53 in the fifth slot. I had this pres up and running since march, so three months of great work. Suddenly, after one hour of work smoke start getting out one of the 312...as you can see in the pictures the GAR 2520 is gone
........ the output transformer was really hot. I checked if something else was black or broken, but I can't see anything damaged or hot on the main board.
The 312 was cabled in a patch bay but I wasn't using it, I was using the VP28s and everything was ok. I turned off the PSU, get the damaged module out and then tested all the other ones. Everything was working as usual. The fuse on the PSU didn't blow. My question is : what the hell happened since I used it for three months and didn't move or changed anything?
Can anyone suggest me what to check before puttin' in another 2520 ? The modules is 24V version in a 51x rack+psu .
here are the other pictures:
http://s827.photobucket.com/user/technoteo/library/Gar2520%20Blown
