3nity
CM75101APC only has 2 ratios 1:5 or 1:10.
I've always used a 150K on the sec. load.
Thats the value everyone uses....
the 1:8 I was talking about is not a Cinemag 75101. But, yeah I should have maybe stuck with the OPs components in the example.3nity said:Mike transformer Ratios are 1:5 or 1:10 nothing else!!
Mike,mikefatom said:I'm using the 600 ohm input.
mikefatom said:can someone explain. I suck at transformers...
mikefatom said:... can anyone confirm that they have used the 150 ohm wiring with RL=150K successfully at all gains?
Mike,mikefatom said:hey mitsos,
I actually mean, that the only configuration that worked perfectly for me is,
Input TX : CM75101APC wired for 150 ohm input.
RL = 17K.
does that all sound normal?? It sounds great here, but just wondering...
cheers
mike
Look where you ended up! Pretty close.[silent:arts] said:...try 15K...
diko2 said:Hi all,
I've just finish 2 gar2520 today. (the assembly manual is really clear by the way...)
I use them with reliquia 312 V3
They seems to work fine but, in both of them, the BD140 and the BD139 are really hot ( can't keep a finger on it...)
Is this normal?
They run on +18v/-18v.
Diko
jsteiger said:Can you guys imagine the stress put on an epoxy potted amp running at 18V or even 20V? Little to no heat dissipation. ??? I really feel good about the open, unpotted design.
