Dusty Circuit
Yes, I think I will. They seem to get a lot of good reviews. Are there any specs/measurements out there?
Hey Rob,Rob Flinn said:How close should I match Q1 & Q2 ??
jsteiger said:Hey Rob,Rob Flinn said:How close should I match Q1 & Q2 ??
Gary has some matching info here.
Cheers, Jeff
Yes, those are the matched ones. Gary actually matches those before he sends the kits to me.Whoops said:Jeff just to be sure about something,
I bought tge gar2520 Kits from your website,
the Q1 abd Q2 transistor that were inside the millmax pins bag where already matched by you?
jsteiger said:Yes, those are the matched ones. Gary actually matches those before he sends the kits to me.Whoops said:Jeff just to be sure about something,
Best, Jeff
Rob Flinn said:jsteiger said:Hey Rob,Rob Flinn said:How close should I match Q1 & Q2 ??
Cheers, Jeff
Sure, but that doesn't tell me how close to match them ? Within 5% or 10% etc ???
gar381 said:WHOOPS
The 2 transistors in the little bag with the millmax pins are already matched.
It's one several advantages of buying the complete kit over just the PCB.
When I match transistors I work with 100 of them at a time. I try to get them
within 2 or 3 HFE most are within 1. Example: if a transistor's HFE is 525 its match
will be between 523 and 527.
Matching is not super Critical at least in my experiments...
Plus or Minus 10 HFE should work fine.
Hope this helps WHOOPS.
GARY
gar381 said:A good way to check these guys is with a signal generator, a scope and a Variac.
GARY
