I'm not sure from the photo but they look like paper-in-oil caps. If so, test for leakage and leave them in there if they are ok. If they are another type and/or leaky, a good quality film cap would be fine.
Thanks. Is this the same one the OP is working on?
I’d forgotten the reference to a 600:600 input into PP grids. I guess the small amount of added noise is okay to avoid the voltage step up of a traditional 600:60-80k in this case?
