audiophreak
Hi All,
I've finished several Tube projects from this fantastic place of sharing and knowledge ... G9 , G-Pultec , NYDave One Bottles x 4 , and some experimenting ;D maybe I am looking in the wrong places , but cant seem to find " the Perfect " PT in the US for these kind of tube thingys , most of the time doing the Gyraf two PT running one backwards for HT .
I purchased a Rondo PT for the D-LA2A ( not finished yet ) and like the secondary assortment , but also like DC heaters ( just my preference ) but didnt like to $90 from overseas , and then also have to add another small PT for phantom if needed.
so I contacted a national PT manufacturer , and have these specs :
Pri: 115v x 2 50/60Hz
Sec1: 9V, 2.5A rms
Sec2: 9V, 2.5A rms
Sec3: 12V, 1.0A rms
Sec4: 36V, 0.1A rms
Sec5: 220V, 0.06A rms
Sec6: 220V, 0.06A rms
Resin filled center with stranded leads
Dimensions: 3.9” x 2.0” approx
Weight: 2.9# approx
that would be enough for 6-8 tubes depending on tubes used , and then I thought maybe they could make this one and one more with just 1 HT and 1 Heater secondary for 2-4 Tube type projects
The one with these listed specs would cost $58 for Qty of 10 ( after $160 proto type ) - I would assume less for more Qty
would anyone be interested in this ??
If there would be enough interested , maybe they would just add them to there stock offereings
Please let me know - I think I might just have them do the proto type anyway for me , or if anyone thinks these voltages and amps are appropriate - or any suggestions
Chip
EDIT - 9v would be for heaters , 12v for relays or lamps/LEDs , 36v for Phantom and 220v for HT
Sec1: 9V, 2.5A rms
Sec2: 9V, 2.5A rms
Sec3: 12V, 1.0A rms
Sec4: 36V, 0.1A rms
Weight: 2.9# approx
Chip
